Command line interface
For those interested, you can use the command line to interact with the Pioreactors. This is called the command line interface (CLI). Log onto either the leader or worker and you can execute the following commands. Full options and up-to-date documentation are available with pio <command> --help.
Worker commands
Interacting with the Pioreactor on the command line are through the pio tool. Available arguments are:
    • pio logs will produce a stream of recent logs events. Logs are stored in /var/log/pioreactor.log.
    • pio kill <job> [<job>...] will safely terminate a <job>. Can kill multiple jobs, ex: pio kill stirring dosing_control
    • pio run <job> <options> will run the <job>. Each job has specific command line arguments. Note that some jobs (like monitor) are started with run-always, see below.
    • pio run-always <job>: run a leader-specific job (ex: monitor). These jobs are independent of any running experiment, and are not killed by pio kill.
    • pio version print the version of the PioreactorApp software.
    • pio update will update the software to the latest version: adding --app will upgrade the PioreactorApp.
    • pio install-plugin <plugin name> will install a plugin
    • pio uninstall-plugin <plugin name> will uninstall a plugin
    • pio list-plugins will list the currently installed plugins
Leader commands
The leader computer interacts with the worker computers using the pios command. Unless otherwise noted, the pios will target all worker computers (see --units to change this). Available pios commands on the leader computer are the following:
  • pios kill <job> [<job>...] terminate the job <job> on the workers. Ex: pios kill dosing_control. Multiple jobs can be killed, ex: pios kill stirring dosing_control
  • pios run <job> on each worker, run the job <job> in the background. Job specific arguments can be specified after. Ex: pios run add_media --ml 1
  • pios update install the latest PioreactorApp code on each worker.
  • pios sync-configs deploy the config.ini files to workers.
  • pios install-plugin <plugin name> will install the plugin on each worker and the leader.
In each of the above commands, the specific workers can be invoked with --units (which can be used multiple times. Ex: pios run stirring --units 1 --units 2.
-y will skip user confirmation of the command to run.
The leader also has their own unique set of pio commands (these commands do not interact with the workers):
  • pio db: open the sqlite3 CLI of the Pioreactor database.
  • pio mqtt: tail the MQTT broker.
  • pio run-always <job>: run a leader-specific job (ex: mqtt_to_db_streaming or watchdog). These jobs are independent of any running experiment, and are not killed by pio kill.
  • pio add-pioreactor <new name>: add a Pioreactor to your cluster, with given (unique) name. Need a blank RPi on the network first. See instructions here.
  • pio update will update the software to the latest version: adding --ui will update the PioreactorUI and adding --app will upgrade the PioreactorApp.
