Grow your cultures, get results, and repeat.
Introducing Pioreactor: the affordable bioreactor. It's user-friendly, flexible, and easy to scale.
Grow, monitor, and control your cultures
Pioreactor helps you design and observe your experiments.
  • Real-time optical density measurements
    Continuously monitor the density and growth rate of your cultures (yeast, bacteria, and algae)
  • Control temperature
    Manually set or automate your bioreactor's temperature to suit your needs
  • Online platform
    Monitor and control the state of your cultures in Pioreactor’s online platform
  • Scale out
    Create a cluster of Pioreactors and control them in parallel from the online platform
  • Liquid handling
    Add and remove media from your bioreactor using Pioreactor’s pumping system
  • And much more...
    Pioreactor has much more to offer: learn about all of Pioreactor's features
Visualize real-time optical density measurements directly from your Pioreactor in our online platform.
Designed for researchers, students, and everyone curious about biology.
Build a cluster of Pioreactors for your cultures.
Horizontally scale your microbiology experiments by connecting together any number of Pioreactors, all controllable from a single interface.
Automate your experiments
Community plugins
Customize and extend your Pioreactor using one of our community-developed plugins. Develop your own plugins and share with others.
Pumping system
Add and remove media from your bioreactor using Pioreactor’s peristaltic pumps. Activate the pumps manually or on triggers. Calibration is streamlined, too!
Built-in automation
Turn your Pioreactor into a turbidostat, chemostat, night/day photo-bioreactor or define your own automation code using our Python API.
Technical specs
  • Ambient to ambient + 20℃ (+ 30℃ with upgrades)
  • Mixing from 100 RPM to > 1000 RPM
  • 20mL vial volumes
  • 4 x 100mA LED outputs
  • 9 x 6 x 12cm footprint
  • OD reading at 900nm wavelength
